Export to Exchange
Export selected objects to a common folder used to exchange data with other Altair products. For example, you can export a die design from Inspire Studio to Inspire Form to perform a stamping simulation.
Note: The common folder is: C:/User/<username>/Documents/Altair/2025.1/Exchange/FromStudio.
- Select one or more objects.
Do one of the following:
- Right-click, and then select Export to Exchange.
- On the File menu, select Export to Exchange.
- Launch another Altair product.
In the Preferences, verify that the path to the Studio
executable has been set. For example, under Category, go
to .
- In the modeling window, right-click, and then select Import Model From Studio.
- Select the desired file.
