Import a File
Open a previously saved scene and merge it with the current one.
Tip: When opening/importing and saving/exporting IGES or STEP files, if the
default import option CT doesn't work properly, try changing
it to PS.
Do one of the following:
- Press Ctrl (Command) + M.
- Select .
Import ignores views configuration information from the incoming file. If the
model contains rendering data such as environments or rendering properties, the
Rendering Data window prompts you to choose how to join the data from the
selected model with what is already in your scene:
- Skip: Imports only geometry, lights, and cameras from the selected library model, but not rendering data such as environments and rendering properties.
- Overwrite: Overwrites rendering data such as environments and rendering properties in your current model with those in the selected library model.
- Merge: Adds the rendering data from the selected library model to your current model. This data is only used if not currently specified in the scene.
Note: Geometry and possible cameras and lights are always added to the scene.
