The Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply
materials, modify the environment, and change the camera position.
A default global environment is included in Inspire Studio to place your model in a 3D context for rendering, but you can also customize the background image.
Default lighting is included in every scene created in Inspire Studio, but you can add lights and shadows to achieve particular lighting conditions. Specify each light's color
and intensity, and choose to use shadows and caustics.
Create copies of objects with a parent-child relationship. When you modify the source objects, all of the instances
are updated automatically in the construction history. This is a scene creation tool that is used mainly for rendering.
Modify the Environment
Lights and Shadows
Default lighting is included in every scene created in Inspire Studio, but you can add lights and shadows to achieve particular lighting conditions. Specify each light's color and intensity, and choose to use shadows and caustics.
