Troubleshooting: Can't Select a Part
Condition
I can't select a part. It's displaying in red.
Cause
You've selected a solid. You can assign only a surface as part.
Remedy
From the solid, you can create a surface using the Surface
Extract tool.
Now you can select the surface when assigning the
part.
