SS-V: 2120 Two-body Symmetric Damped Oscillators System
Test No. VM13 Determine the frequency and damping rate
of a 1D damped oscillator.
Definition
The material properties are:
Rigid body, m = 1 kg, k = 1 N/m, c0 = 1 Ns/m, c1 = 0.1
Ns/m
Modeling and
Results
The spring and damper can be modeled with a shock absorber or a
bushing. To restrict motion to one dimension, sliding conditions are applied on two
sides of the cube-shaped bodies. Frequency and rate of damping are compared to the
values from the analytical solution.
SimSolid
Analytical solution
% Difference
Mode 1
Frequency, Hz
0.15876
0.158956
0.12%
Mode 1
Damping rate, 1/s
0.049752
0.05
0.50%
Mode 2
Frequency, Hz
0.2201
0.219236
0.39%
Mode 2
Damping rate, 1/s
1.0476
1.05
0.23%
1 Kausel E.,
“Advanced Structural Dynamics”, Cambridge University Press, 2017, Section 3:
”Multiple Degree of Freedom Systems” (general equations). Also see Additional
Comments.
