SS-T: 1000 Geometry Import
Tutorial Level: Beginner Import materials from CAD files.
- Purpose
- SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
- Learn how to specify metadata attributes for materials and import materials from CAD files.
- Model Description
The following geometry file is needed for this tutorial:
- grapple-v1_assembly.asm.3
Specify Metadata Attribute
Identify the metadata attribute for the material property.
- In the main window, click
- Select the Import materials check box.
For Custom metadata attributes, enter the
attribute.
- Click OK.
Verify that a material with the name STEEL is available in SimSolid.
Import Geometry
- Open a new SimSolid session.
Click
Import from file .
- In the Open geometry files dialog, choose grapple-v1_assembly.asm.3.
Click Open.
The assembly will load in the modeling window. STEEL is applied to the parts.
Figure 5.
