Tutorial Level: Beginner Clip the model assembly with a plane.
Purpose
SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
Use the Clip Assembly with Plane display option.
Model Description
The following file is needed for this tutorial:
ClipAssemblyWithPlane.ssp
This file has the following specifications:
Material is set to Steel for all parts.
Regular connections with default gap and penetration tolerance.
Open Project
Start a new SimSolid session.
In the main window toolbar, click Open Project.
In the Open project file dialog, choose
Click OK.
Clip Assembly With Plane
In the main menu toolbar,
select Clip an assembly
with a place.
Figure 2. The default direction of the plane is along the XY plane.
Use Shift + mouse wheel to slowly move the section
plane in the Z direction.
You can use Control + mouse wheel for faster
movement.
Use Control + left mouse button to select a surface and
orient the plane along the normal to the surface.
Figure 3.
Use arrows to change the angle of the clipping plane. Using the stem part, the
manipulator can be positioned anywhere on the screen.
Use the bottom square to change the direction of the clipping plane and the
circular ring can be used to rotate the manipulator.
