Cloud Environment captures the cloud region and networking infrastructure within a
cloud credential to support deployment of a Node Class.
Figure 1. Cloud Environments in NavOps
Use Add Environment to add an AWS, Azure, GCP or OCI
environment. The list of registered environments is displayed in a table. You can
switch to a card view. You can search the list by name or filter by cloud
credential.
Tip: Click view () to open the details of the credentials in a panel. The
panel can be minimised and will persist across the screens in the application till
it is closed. You can use the links at the top of the panel to navigate to different
screens of the application. You can copy the information from the various fields in
the panel.
Click settings () to select the
columns to be displayed in the table.Figure 2. Environments Columns
