Clusters
NavOps supports Accelerator, PBS Professional, Grid Engine and Slurm workload managers. The type, id, name, state and other details of the registered clusters are displayed in the cluster page.
Use Add Cluster to add an Accelerator, PBS Professional, Grid Engine or Slurm cluster. The list of registered clusters is displayed. You can search the list by name and description or filter by cluster type. You can also delete a cluster. You can bookmark a cluster from the list to be displayed in the side navigation bar. You can search for a cluster from the side navigation bar.
Click the name of a cluster to open the dashboard for the cluster. You can register and deploy the cluster. If a cluster is installed, you can view the status of the agent services, active automations, cost center reports and recent activities. You can manage nodes, node configurations and automations for the cluster.
Click settings (
) to select the columns to be displayed in the
table.
