Generate API Keys
NavOps uses API keys to connect the NavOps server, WLM agent, head node and cloud nodes. Each cluster has a dedicated API KEY, if you would like to generate additional key please use the following instructions. The key is generated and displayed once. Make sure you save it as you won't be able to access it again. The key is generated for a specific cluster. The key is set on the deployed nodes. It is also present in the NavOps agent on the head node and the MoMs. The default expiry date of the key is one year. When the key expires, you can generate another one and replace the key manually on the head node.
To generate an API key:
- Open .
 - Click Add API Key.
 - Enter a name and description.
 - Select an expiry date or use the default date (1 year duration).
                Click Save.
                Your personal API key is generated and displayed.
 - Copy it and save it as it will not be displayed again.
                Click Back to list.
                The new API key is added to the list of API Keys.
