API Keys
NavOps uses API keys to connect the NavOps server, WLM agent, head node and cloud nodes. The key is generated and displayed once. The key is generated for a specific cluster. It is set on the deployed nodes. It is also present in the NavOps agent on the head node and the MoMs. The default expiry date of the key is one year. When the key expires, you can generate another one and replace the key manually on the head node.
Click Add API Key to generate and add a new API Key. You can specify an expiry date or use the default date (1 year duration).
Click settings (
) to select the columns to be displayed in the
table.
