Add an Oracle Cloud Credential
Add an existing Oracle Cloud account to NavOps so that you can create a cloud environment.
You should have the following information stored in a
file:
- User OCID generated when creating the Oracle user.
- Tenancy OCID.
- Root compartment OCID.
- Fingerprint of the public key generated for the Oracle user.
- RSA private key that was generated for the Oracle user.
This information is necessary to create a cloud credential in NavOps. If you do not have this information see Create an Oracle Cloud User Account, Generating an SSH Public for the Oracle Cloud User, Obtain the Compartment Identifier and Obtain the Tenancy Identifier.
- Login to NavOps.
- Go to Clouds, and then select Credentials.
- Click Add Cloud Credentials
- Click Select in the Oracle Cloud tile.
Enter the following to add a cloud credential:
- (Optional) For Tags, enter the suitable tags for the credentials.
- Click Test to check the credentials. If an error message is displayed, inspect the details from the Tasks list.
- Click Save.
