The Data Prep Studio Toolbar and Windows
The Data Prep Studio interface includes a toolbar that remains visible regardless of the window or page you access.
The Data Prep Studio toolbar includes several tools, each of which allow you to carry out a specific action towards completing data integration, preparation, and transformation.
Tool Descriptions
Tool |
Description |
Allows you to:
Allows you to open a file. It also allows you to:
Allows you to:
Allows you transform the columns of your unified table. For instance, you can:
Allows you to:
Allows you to join data from two or more tables, so that you have one unified table to work with. |
Allows you to create, view, modify, and manage summaries |
Allows you to export your workspace to several popular file formats and file and database systems. |
Allows you to build a table by selecting fields on a document. The resulting table then becomes available in the Preview Window, so you can load it and then eventually combine with other tables or data sources. This window is only available only when you open a report document. |
Clicking this icon launches a popup that provides complete details on your workspace. |
Allows you to save your current workspace. Your workspace includes:
Opens the Library, which will then allow you to select and use data sources made available to you. |
Presents setting options that allow you to, among others:
