Generate a Report for Steady State Analysis
Generate a PDF report from the results of a completed simulation.
A PDF report with details of the model, material data, boundary conditions, flownet diagrams, and results of computed variables in predefined orientations, is generated. It is stored in the same directory as the run history specified in Preferences.
- Open the model from a completed run.
- On the ribbon, click the Extrusion tab.
From the Run tools, select the
Report icon.
The result is loaded and all the necessary images are captured. The *.PDF report is generated.
Upon completion, a message tells you where the report is located. The generated report has the name <analysis_name>Report.PDF.
