Cleaning Up CAD on Import
Run a diagnostic test on an imported CAD model to review and fix issues with parts.
Important: Before importing CAD, turn on the ability
to run diagnostics in the Preferences:
- On the File menu, click the Preferences button to open the Preferences window.
- Under Category, select Inspire > Geometry.
- Under Preference, scroll down to Import from CAD File.
- For Fastest import, select With diagnostics.
- To open the CAD file, press Ctrl+O.
- In the History Browser, right-click the CAD model, and then select Run Import Diagnostics.
- In the Diagnostics table, the Name of the parts and the corresponding Issues are listed. For details, see Diagnosing CAD Geometry Issues
- By default, all of the available import options—except Alternate Convert—are used to fix the model. To customize the import options, click the Advanced button, right-click a column header, and then turn on/off the desired import options. For details, see Setting CAD Import Options.
- Select the desired part, and then click the Fix button.
The Diagnostics table displays descriptions of CAD geometry issues that may appear when importing CAD.
| Error | Description |
| Not converted | The part couldn't be converted from CT to Parasolid, because too many surfaces or curves couldn’t be converted. The Inspire part is created, but it is empty. |
| Missing faces | Some faces couldn't be converted and are missing in the resulting part. |
| Not solid | After being converted to Parasolid, the part is no longer a solid. |
| Split | The resulting Parasolid part is split, because knitting failed partially or completely. The CT part is converted into an assembly; each piece is an Inspire part within this assembly. |
| Invalid | The Parasolid check detected errors in the resulting part. While the geometry may not be a valid Parasolid part, you could still work with it. |
| Corrupt | The Parasolid check detected that the part is corrupt. The resulting Inspire part remains, but it is empty. |
| Not tessellated | Since the part couldn't be tessellated at all, the part is empty. |
| Partially tessellated | Tessellation failed for some faces, which will be deleted. |
CAD import options allow you to configure preprocessing, conversion, and postprocessing steps when importing CAD.
| Option | Type | Description |
| Healing (also known as Pre-healing) | Preprocessing | Heal the selected part. |
| Alternate Convert | Conversion | If regular conversion (trimming and knitting) doesn't give the expected results, you can turn on this option to save the selected CT part into a temporary .x_b file that will be reloaded by Parasolid. |
| Sew | Conversion | When knitting fails, the CT part is converted into an assembly, holding all pieces. Turn on this option to combine (partially or completely) the pieces. |
| Solidify | Postprocessing | When there are issues such as gashes, small missing faces, sliver
faces (faces that were deleted because they were non-tessellated),
you can turn on this option to help make parts solid. When tessellation partially fails, non-tessellated faces are deleted and the Solidify operation is performed again. |
| Reset Edge Precision | Postprocessing | Recalculate the tolerant edge geometry to improve
precision. While turning this option may not topologically or visually modify the part, it may fix some failing modeling operations. |
Note: Solidify and Reset Edge Precision are the only
postprocessing options relevant to XT-based CAD formats (Parasolid, JT, SW, NX).
Since XT-based CAD parts don't need to be converted to Parasolid, Healing (aka
Pre-healing), Alternate Convert, and Sewing aren't applicable.
