Shock Waves
Shocks are non-isentropic phenomena, that is, entropy is not conserved, and necessitates a special formulation.
The missing energy is generated by an artificial bulk viscosity as derived by von Neumann and Richtmeyer. 1 This value is added to the pressure and is computed by:
Where,
- l
- Is equal to or to the characteristic length
- Volume
- Volumetric compression strain rate tensor
- Speed of sound in the medium
The values of
and
are adimensional scalar factors defined as:
- is a scalar factor on the quadratic viscosity to be adjusted so that the Hugoniot equations are verified. This value is defined by the user. The default value is 1.10.
- is a scalar factor on the linear viscosity that damps out the oscillations behind the shock. This is user specified. The default value is 0.05.
Default values are adapted for velocities lower than Mach 2. However, for viscoelastic materials (LAW34, LAW35, LAW38) or honeycomb (LAW28), very small values are recommended, that is, 10-20.
1 Von Neumann J. and Richtmeyer R., A method for the numerical
calculation of hydrodynamical shocks, Journal of applied physics,
1950.
