Pulley Type Spring Elements (TYPE12)
Pulley type springs are defined by TYPE12 element property. A general representation can be seen in Figure 1. It is defined with three nodes, where node 2 is located at the pulley position. Other properties such as stiffness, damping, nonlinear and plastic effects are the same as for the other spring types, and are defined using the same format.
A deformable "rope" joins the three nodes, with the mass distribution as follows: one quarter at node 1; one quarter at node 3 and one half at node 2.
Coulomb friction can be applied at node 2, which may also take into account the angle between the two rope strands.
The two rope strands have to be long enough to avoid node 1 or node 3 sliding up to node 2 (the pulley). If this occurs, either node 1 or 3 will be stopped at node 2, just as if there were a knot at the end of the rope.
Figure 1. Pulley Type Spring Element Representation
Time Step
The time step is calculated using the relation:
Δt= ( KM+ C 2 )C 2K MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bGaeyypa0ZaaSaaaeaadaqadaqaamaakaaabaGaam4saiaad2ea cqGHRaWkcaWGdbWaaWbaaSqabeaacaaIYaaaaaqabaaakiaawIcaca GLPaaacqGHsislcaWGdbaabaGaaGOmaiaadUeaaaaaaa@42ED@
This is the same as for TYPE4 spring elements, except that the stiffness is replaced with twice the stiffness to ensure stability with high friction coefficients.
Linear Spring
See Linear Spring; the explanation is the same as for spring TYPE4.
Nonlinear Dashpot
See Nonlinear Dashpot; the explanation is the same as for spring TYPE4.
Friction Effects
Pulley type springs can be modeled with or without Coulomb friction effects.
Forces without Friction
Without friction, the forces are computed using:
| F 1 | = | F 2 | = K δ + C d δ d t
Where,
δ
Total rope elongation = l l 0 with l = l 12 + l 23
K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamytaaaa@36C8@
Rope stiffness
C MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamytaaaa@36C8@
Rope equivalent viscous damping
Forces with Coulomb Friction
If Coulomb friction is used, forces are corrected using:
F = K ( δ 1 + δ 2 ) + C ( d δ 1 d t + d δ 2 d t )
Δ F = max ( K ( δ 1 + δ 2 ) + C ( d δ 1 d t + d δ 2 d t ) , F tanh ( β μ 2 ) )
| F 1 | = F + Δ F
F 2 = F 1 F 3
| F 3 | = F Δ F
Where,
δ 1
Elongation of strand 1-2
δ 2
Elongation of strand 2-3
