/SLIPRING/SHELL
Block Format Keyword Define a 2D slipring for seatbelt elements defined with /MAT/LAW119 and /PROP/TYPE9.
/SLIPRING/SHELL/slipring_ID/unit_ID
slipring_title
El_Gr1 El_Gr2 Gr_Nod Sens_ID Fl_flag Ed_factor
fct_ID1 fct_ID2 Fric_d Xscale1 Yscale2 Xscale2
fct_ID3 fct_ID4 Fric_s Xscale3 Yscale4 Xscale4
Definition
slipring_ID Slipring identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
slipring_title Slipring title.
El_Gr1 ID of first group (or set) of elements in slipring. 2 3
El_Gr2 ID of second group (or set) of elements in slipring. 2 3
Gr_Nod Group of anchorage nodes. 4
Sens_ID Sensor identifier used for slipring locking.
= 0
Slipring is unlocked.
(Integer)
Fl_flag Sliding direction control flag.
= 0 (Default)
Slip in both directions.
= 1
Slip from elements of El_Gr1 to El_Gr2 only.
= 2
Slip from elements of El_Gr2 to El_Gr1 only.
(Integer)
Ed_factor Exponential decay factor for Coulomb friction.
(Real)
[sm]
fct_ID1 Dynamic Coulomb friction coefficient as a function of time identifier.
(Integer)
fct_ID2 Dynamic Coulomb friction coefficient as a function of normal force identifier,
(Integer)
Fric_d
If fct_ID1= 0
Constant dynamic Coulomb friction coefficient.
If fct_ID1 > 0
Ordinate scaling factor for function fct_ID1.
(Real)
Xscale1 Abscissa scaling factor for function fct_ID1.
(Real)
[s]
Xscale2 Abscissa scaling factor for function fct_ID2.
(Real)
[N]
Yscale2 Ordinate scaling factor for function fct_ID2.
(Real)
fct_ID3 Static Coulomb friction coefficient as a function of time identifier.
(Integer)
fct_ID4 Static Coulomb friction coefficient as a function of normal force identifier.
(Integer)
Fric_s
If fct_ID3= 0
Constant static Coulomb friction coefficient.
If fct_ID3> 0
(Real)
Xscale3 Abscissa scaling factor for function fct_ID3.
(Real)
[s]
Yscale4 Ordinate scaling factor for function fct_ID4.
(Real)
Xscale4 Abscissa scaling factor for function fct_ID4.
(Real)
[N]
  1. The /SLIPRING/SHELL option is an extension to seatbelt shell elements of the /SLIPRING/SPRING. It can be seen as sequence of /SLIPRING/SPRING. The parameters are almost the same; therefore, refer to /SLIPRING/SPRING for a detailed explanation concerning parameters, slipring updates during the run, locking and friction.
  2. The /SLIPRING/SHELL can only be connected to seatbelt shell elements, shells using a seatbelt material (/MAT/LAW119 (SH_SEATBELT)).
  3. The /SLIPRING/SHELL is defined by the 2 groups of shell elements initially connected to the slipring, El_Gr1, El_Gr2 and a group of nodes Gr_Nod used to define the position of the slipring. The common node between the elements of El_Gr1 and El_Gr2 must be at the same position as Gr_Nod.
  4. The slipring must be represented by a line; therefore, the nodes of Gr_Nod must be aligned and can not be nodes of the seatbelt shell elements. All the nodes of Gr_Nod must belong to a single rigid body or boundary condition (all DOF fixed).
  5. At any time, the common nodes of the shell seatbelt elements are kinematically attached to the corresponding anchorage nodes. No other kinematic condition can be applied to theses nodes.
  6. Shell elements that are connected to the slipring are deactivated and are reactivated when they are outside of the slipring. The activation/deactivation of shell elements is progressive, and a scaling factor computed from the distance between the shell element and the slipring is applied on the stresses.
  7. 2D seatbelt uses /PROP/TYPE9 (SH_ORTH) with IP = 24 and Iskew > 0.
