/RETRACTOR/SPRING
Block Format Keyword Define 1D retractor for seatbelt defined with material /MAT/LAW114 and property /PROP/TYPE23.
/RETRACTOR/SPRING/retractor_ID/unit_ID
retractor_title
El_ID node_ID Elem_size
sens_ID1 Pull_Lock fct_ID1 fct_ID2 Yscale1 Xscale1
sens_ID2 Typ_pre Fmax fct_ID3 Yscale2 Xscale2
Definition
retractor_ID Retractor identifier.
(Integer)
unit_ID (Optional) Unit identifier.
(Integer)
retractor_title Retractor title.
El_ID Element ID initially connected to retractor.
(Integer, maximum 10 digits)
node_ID Anchorage node ID. 1
(Integer)
Elem_size Target element size for released elements. 4
(Real)
[ m ]
sens_ID1 Sensor identifier for retractor locking. 3
(Integer)
Pull_Lock Authorized amount of seatbelt release before locking. 6
(Real)
[ m ]
fct_ID1 Function identifier defining loading force scale factor versus pullout when retractor is locked. 5
(Integer)
fct_ID2 Function identifier defining unloading force scale factor versus pullout when retractor is locked. 5
(Integer)
Yscale1 Retractor force.
If fct_ID1= 0: constant force (Default = 0)
If fct_ID1 ≠ 0: ordinate scaling factor for fct_ID1 and fct_ID2 (Default = 1).
(Real)
[ N ]
Xscale1 Abscissa scaling factor for function fct_ID1 and fct_ID2.
Default = 1 (Real)
[ m ]
sens_ID2 Sensor identifier used for pretension activation. 7
(Integer)
Typ_pre Pretensioner type. 8
= 0
No pretension.
= 1
Pretension is defined by pull in length versus time function.
= 2
Pretension is maximum of force versus time function or retractor force.
= 3
Pretension is maximum of force versus time function or retractor force and Pull_Lock release.
= 4
Pretension is sum of force versus time function and retractor force.
= 5
Pretension is defined by energy versus time function.
Default = (Integer)
Fmax Maximum retractor force for pretensioner locking (for Typ_pre = 1 and 5 only).
(Real)
[ N ]
fct_ID3 Function identifier defining pretension as a function of time, force versus time, length versus time, or energy versus time. 8
(Integer)
Yscale2 Ordinate scaling factor for function fct_ID3.
(Real)
[ N ] , [ m ] or [ J ]
Xscale2 Abscissa scaling factor for function fct_ID3.
(Real)
[ s ]
  1. The retractor is defined by 1 spring seatbelt element initially connected to the retractor and the node node_ID used to define the position of the retractor. The element El_ID must have a node initially at the same location as node node_ID. node_ID must not be a node of the seatbelt element.
  2. Seatbelt spring elements can be initially positioned inside the retractors in order to be released during the run. These elements are automatically detected and deactivated until they are released from the retractor. This part of the seatbelt must be connected to element El_ID and the nodes of these elements must be at the same location as node node_ID.
  3. The initial retractor force can either be defined by Yscale1 if fct_ID1=0 or by the 1st point of the fct_ID1(x=0) * Yscale1.
  4. When the retractor is unlocked, reference length of the element in the retractor is adjusted in order to ensure a constant force applied on the retractor.
  5. When the element size in the retractor reaches Elem_size, a new element is released. In case there are no more elements to release, the last element in the retractor can continue to grow.
    In case fct_ID1 and fct_ID2 are defined in the model, both curves must have positive slope.
  6. The retractor is locked when the amount of seatbelt released reaches Pull_Lock value after the sensor sens_ID1 activation.
  7. When the retractor is locked, the force applied on the retractor is defined by fct_ID1 and fct_ID2. The force versus pullout is:
    • For loading:
      F r e t r a c t o r = Y s c a l e 1 . f c t _ I D 1 . ( L o c k e d _ p u l l o u t X s c a l e 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGYbGaamyzaiaadshacaWGYbGaamyyaiaadogacaWG0bGa am4BaiaadkhaaeqaaOGaeyypa0JaamywaiaadohacaWGJbGaamyyai aadYgacaWGLbWaaSbaaSqaaiaaigdaaeqaaOGaaiOlaiaadAgacaWG JbGaamiDaiaac+facaWGjbGaamiramaaBaaaleaacaaIXaaabeaaki aac6cadaqadaqaamaalaaabaGaamitaiaad+gacaWGJbGaam4Aaiaa dwgacaWGKbGaai4xaiaadchacaWG1bGaamiBaiaadYgacaWGVbGaam yDaiaadshaaeaacaWGybGaam4CaiaadogacaWGHbGaamiBaiaadwga daWgaaWcbaGaaGymaaqabaaaaaGccaGLOaGaayzkaaaaaa@639E@
    • For unloading:
      F r e t r a c t o r = Y s c a l e 1 . f c t _ I D 2 . ( L o c k e d _ p u l l o u t X s c a l e 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGYbGaamyzaiaadshacaWGYbGaamyyaiaadogacaWG0bGa am4BaiaadkhaaeqaaOGaeyypa0JaamywaiaadohacaWGJbGaamyyai aadYgacaWGLbWaaSbaaSqaaiaaigdaaeqaaOGaaiOlaiaadAgacaWG JbGaamiDaiaac+facaWGjbGaamiramaaBaaaleaacaaIYaaabeaaki aac6cadaqadaqaamaalaaabaGaamitaiaad+gacaWGJbGaam4Aaiaa dwgacaWGKbGaai4xaiaadchacaWG1bGaamiBaiaadYgacaWGVbGaam yDaiaadshaaeaacaWGybGaam4CaiaadogacaWGHbGaamiBaiaadwga daWgaaWcbaGaaGymaaqabaaaaaGccaGLOaGaayzkaaaaaa@639F@
  8. The retractor can also act as a pretensioner when sensor sens_ID2 is activated. The retractor applies force to pull the seatbelt inside the retractor:
    • If Typ_pre = 1:
      The function fct_ID3 defines the length of seatbelt pulled in as a function of time. In order to ensure that the effort on the seatbelt is not too high, the pretension is deactivated when the force in the retractor reaches Fmax.
      F t o t a l = Y s c a l e 2 . f c t _ I D 3 . ( t X s c a l e 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWG0bGaam4BaiaadshacaWGHbGaamiBaaqabaGccqGH9aqp caWGzbGaam4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaaG OmaaqabaGccaGGUaGaamOzaiaadogacaWG0bGaai4xaiaadMeacaWG ebWaaSbaaSqaaiaaiodaaeqaaOGaaiOlamaabmaabaWaaSaaaeaaca WG0baabaGaamiwaiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSba aSqaaiaaikdaaeqaaaaaaOGaayjkaiaawMcaaaaa@53CA@
    • If Typ_pre = 2:
      The function fct_ID3 defines the pull-in force as a function of time. The total force in the element is the sum of maximum of the retractor force and the pretension force defined by fct_ID3.
      F t o t a l = max . [ F r e t r a c t o r , Y s c a l e 3 . f c t _ I D 3 ( t X s c a l e 2 ) ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWG0bGaam4BaiaadshacaWGHbGaamiBaaqabaGccqGH9aqp ciGGTbGaaiyyaiaacIhacaGGUaWaamWaaeaacaWGgbWaaSbaaSqaai aadkhacaWGLbGaamiDaiaadkhacaWGHbGaam4yaiaadshacaWGVbGa amOCaaqabaGccaGGSaGaamywaiaadohacaWGJbGaamyyaiaadYgaca WGLbWaaSbaaSqaaiaaiodaaeqaaOGaaiOlaiaadAgacaWGJbGaamiD aiaac+facaWGjbGaamiramaaBaaaleaacaaIZaaabeaakiaacIcada WcaaqaaiaadshaaeaacaWGybGaam4CaiaadogacaWGHbGaamiBaiaa dwgadaWgaaWcbaGaaGOmaaqabaaaaOGaaiykaaGaay5waiaaw2faaa aa@6295@
    • If Typ_pre = 3:
      The total force in the element is the same as Typ_pre = 2, but the seatbelt will be release by the value Pull_Lock before the retractor gets locked.
    • If Typ_pre = 4:
      The function fct_ID3 defines the pull-in force as a function of time. The total force in the element is the sum of the retractor force and the pretension force define by fct_ID3
      F t o t a l = F r e t r a c t o r + Y s c a l e 2 . f c t _ I D 3 ( t X s c a l e 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWG0bGaam4BaiaadshacaWGHbGaamiBaaqabaGccqGH9aqp caWGgbWaaSbaaSqaaiaadkhacaWGLbGaamiDaiaadkhacaWGHbGaam 4yaiaadshacaWGVbGaamOCaaqabaGccqGHRaWkcaWGzbGaam4Caiaa dogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaaGOmaaqabaGccaGGUa GaamOzaiaadogacaWG0bGaai4xaiaadMeacaWGebWaaSbaaSqaaiaa iodaaeqaaOGaaiikamaalaaabaGaamiDaaqaaiaadIfacaWGZbGaam 4yaiaadggacaWGSbGaamyzamaaBaaaleaacaaIYaaabeaaaaGccaGG Paaaaa@5D4E@
    • If Typ_pre = 5:
      The function fct_ID3 defines the pull-in energy as a function of time. Fmax can be defined to ensure the effort in the element is not too high and the pretension is deactivated when Fmax is reached. The pull-in energy being defined by:
      Y s c a l e 2 . ( f c t _ I D 3 . ( t X s c a l e 1 ) ) = ∫ t _ p r e n t e n s t ( F t o t a l ( t ) . Δ p u l l i n ( t ) d t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamywaiaado hacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaaikdaaeqaaOGa aiOlamaabmaabaGaamOzaiaadogacaWG0bGaai4xaiaadMeacaWGeb WaaSbaaSqaaiaaiodaaeqaaOGaaiOlamaabmaabaWaaSaaaeaacaWG 0baabaGaamiwaiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaS qaaiaaigdaaeqaaaaaaOGaayjkaiaawMcaaaGaayjkaiaawMcaaiab g2da9maapehabaWaaeWaaeaacaWGgbWaaSbaaSqaaiaadshacaWGVb GaamiDaiaadggacaWGSbaabeaakiaacIcacaWG0bGaaiykaiaac6ca cqqHuoardaWgaaWcbaGaamiCaiaadwhacaWGSbGaamiBaiaadMgaca WGUbaabeaakiaacIcacaWG0bGaaiykaiaadsgacaWG0baacaGLOaGa ayzkaaaaleaacaWG0bGaai4xaiaadchacaWGYbGaamyzaiaad6gaca WG0bGaamyzaiaad6gacaWGZbaabaGaamiDaaqdcqGHRiI8aaaa@7236@
    • When the pretension is deactivated, the retractor is also locked. The abscissa of the fct_ID1 and fct_ID2 is shifted in order to start at the pretension deactivation force value.
  9. When a spring seatbelt element is in the retractor, viscosity is deactivated.
  10. When a spring element is connected to a retractor its reference length L 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaaIWaaabeaaaaa@37AE@ is modified. In order to prevent the stiffness becoming infinite and the time step being too small in case of pull-in, a maximum value is used for the stiffness, computed from L min MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaaciGGTbGaaiyAaiaac6gaaeqaaaaa@39C6@ defined in seatbelt material.
    K = k max ( L min , L 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4saiabg2 da9maalaaabaGaam4AaaqaaiGac2gacaGGHbGaaiiEaiaacIcacaWG mbWaaSbaaSqaaiGac2gacaGGPbGaaiOBaaqabaGccaGGSaGaamitam aaBaaaleaacaaIWaaabeaakiaacMcaaaaaaa@4344@
