/GRTRUS/MAT
Block Format Keyword Describes the truss material groups which belong to given materials.
Enter selected items numbers (any number may be input, 10 per Line)
| /GRTRUS/MAT/grtruss_ID/unit_ID | |||||||||
| grtruss_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grtruss_ID | Truss group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grtruss_title | Truss group
| item_ID1, item_ID2,... item_IDn | List of material
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
