/GRTRUS/GENE
Block Format Keyword Generate a group of truss elements by listing the first and last element IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
| /GRTRUS/GENE/grtrus_ID/unit_ID | |||||||||
| grtrus_title | |||||||||
| first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
| grtrus_ID | Truss group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grtrus_title | Truss group
| first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
truss identifiers (Integer) |
