/GRTRUS/BOX or /GRTRUS/BOX2
Block Format Keyword Describes the truss box groups which are inside the box.
/GRTRUS/BOX/grtruss_ID/unit_ID or /GRTRUS/BOX2/grtruss_ID/unit_ID | |||||||||
grtruss_title | |||||||||
box_ID |
Definition
grtruss_ID | Truss group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grtruss_title | Truss group
box_ID | Box identifier, which is
defined in Boxes (Integer, maximum 10 digits) |
- If type is
BOX, all elements having all nodes inside the box or on its
surface are selected.
If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
