/GRSHEL/SHEL
Block Format Keyword Describes the shell number groups.
Enter selected items numbers (any number may be input, 10 per Line)
/GRSHEL/SHEL/grshell_ID/unit_ID
grshell_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
Definition
grshell_ID Shell group identifier
(Integer, maximum 10 digits)
unit_ID Unit identifier
grshell_title Shell group title
item_ID1, item_ID2,..., item_IDn List of shell element identifiers
(Integer)
  1. Shell groups cannot contain 3 node shell elements (use /GRSH3N instead).
  2. If item_ID is a negative number, the item number is deleted from the group.
