/GRSHEL/GENE
Block Format Keyword Generate a group of shell elements by listing the first and last element IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up
to 5 per Line). All nodes between first_ID and
last_ID are selected.
| /GRSHEL/GENE/grshell_ID/unit_ID | |||||||||
| grshell_title | |||||||||
| first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
| grshell_ID | Shell group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grshell_title | Shell group
| first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
shell identifiers (Integer) |
