/GRSH3N/PART
Block Format Keyword Describes the 3 node shell part groups which belong to given parts.
Enter selected items numbers (any number may be input, 10 per Line)
| /GRSH3N/PART/grsh3n_ID/unit_ID | |||||||||
| grsh3n_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grsh3n_ID | 3 node shell group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grsh3n_title | 3 node shell group
| item_ID1, item_ID2,..., item_IDn | List of parts
identifiers (Integer) |
- The 3 node shell groups cannot contain 4 node shell elements (use /GRSHEL instead).
- If item_ID is a negative number, the item number is deleted from the group.
