/GRSH3N/BOX or /GRSH3N/BOX2
Block Format Keyword Describes the 3 node shell groups which are inside the box.
Only one box_ID is allowed:
| /GRSH3N/BOX/grsh3n_ID/unit_ID or /GRSH3N/BOX2/grsh3n_ID/unit_ID | |||||||||
| grsh3n_title | |||||||||
| box_ID | |||||||||
Definition
| grsh3n_ID | 3 node shell group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grsh3n_title | 3 node shell group
| box_ID | Box identifier, which is
defined in Boxes (Integer, maximum 10 digits) |
- The 3 node shell groups cannot contain 4 node shell elements (use /GRSHEL instead).
- If type is BOX, all elements
having all nodes inside the box or on its surface are selected.
If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
