/GRBEAM/GENE
Block Format Keyword Generate a group of beam elements by listing the first and last element IDs in the range.
For each list, enter first beam and last beam (any number of lists may be input, up
                to 5 per Line). All beams between first_ID and
                    last_ID are selected
| /GRBEAM/GENE/grbeam_ID/unit_ID | |||||||||
| grbeam_title | |||||||||
| first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
Definition
| grbeam_ID | Beam group
                                    identifier (Integer, maximum 10 digits)  |
| unit_ID | Unit identifier (Integer, maximum 10 digits)  |
| grbeam_title | Beam group
                                    title (Character, maximum 100 characters)  |
| first_ID1, last_ID1,..., first_IDn, last_IDn | List of first and last
                                beam identifiers (Integer)  |
