/GRBEAM/BOX or /GRBEAM/BOX2
Block Format Keyword Describes the beam groups which are inside the box.
Only one box_ID is allowed:
| /GRBEAM/BOX/grbeam_ID/unit_ID or /GRBEAM/BOX2/grbeam_ID/unit_ID | |||||||||
| grbeam_title | |||||||||
| box_ID | |||||||||
Definition
| grbeam_ID | Beam group
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| grbeam_title | Beam group
title. (Character, maximum 100 characters) |
| box_ID | Box identifier, which is
defined in Boxes. (Integer, maximum 10 digits) |
- If type is
BOX, all elements having all nodes inside the box or on its
surface are selected.
If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
