Adiabatic Analysis
Adiabatic analysis is a coupled thermal-structural analysis. This analysis is applicable in modeling systems with inelastic strain, which can lead to quick heating of the material without sufficient time for the heat to be transmitted.
Input
A summary of relevant input file entries for adiabatic analysis.
- Heat and structure are coupled at each time step.
- The adiabatic analysis subcase setup consists of the following.
- The implicit nonlinear subcase. This subcase should be one of:
- Small displacement nonlinear Static analysis
- Large displacement nonlinear Static analysis
- Small displacement nonlinear Transient analysis
- Large displacement nonlinear Transient analysis
- An ADIABATIC Subcase Information Entry should be specified in the implicit nonlinear subcase.
- Three dimensional elements and Axisymmetric elements are currently supported.
- Some parts of the model are made of elastic material, and other parts are inelastic.
- Elasto-plasticity (MATS1), Visco-elasticity (MATVE), and Cohesive elements (MCOHE, MCOHED) are supported for defining inelastic materials for adiabatic analysis.
- Cohesive elements only work as a heat source. Heat conduction or specific heat effects are not considered for cohesive elements.
- All the elements in a model participate in the structural analysis, but only the elements with thermal material participate in thermal analysis.
Example Subcase
SUBCASE 1
ANALYSIS NLSTAT
ADIABATIC
SPC = 1
LOAD = 2
NLPARM = 5
VISCO = 12
NLOUT = 10
Input Entries
The following tables summarize the input entries for an adiabatic analysis.
Entry | Purpose |
ADIABATIC | Activates adiabatic analysis for an implicit nonlinear subcase. |
Entry | Purpose |
MAT4 | Defines thermal material and INELAHTF field which is the fraction of inelastic energy converted to heat source in adiabatic analysis. |
MAT5 | Defines thermal material and INELAHTF field which is the fraction of inelastic energy converted to heat source in adiabatic analysis. |
Output
Supported output requests for adiabatic analysis.
- Grid temperature
- Temperature gradient
- Heat flux
- Element heat energy
- Incremental heat power density (per time, per volume)
- Total heat power density (per volume)
