Filemenu XML
Format of customized filemenu.xml files.
XML Overview
Use filemenu.xml to load additional plug-in features through the included *.xml files. It references all required resources by relative paths.
The $EXTENSION_DIR variable is supported for all command attributes in the XML files.
Tags
root
Base container for the toolbar.
        - Attributes
 - none
 - Children
 - button
button
Each individual button is specified by name/value pairs.
        - Attributes
 - text, tag, tooltip, image, command
 - Children
 - item
item
Each individual item is specified by name/value pairs.
        - Attributes
 - text, tag, hint, command
 - Children
 - none
Example XML
<root>
  <button tag="Ext_Filemenu_HV1"
           text="Custom Entry 1"
           tooltip="Custom file menu entry 1"
           image="fileHelpStrip-24.png">
    <item tag="Ext_Filemenu_HV1_A"
           text="Custom Option A"
           hint="Custom file menu sub-entry A"
           command="tcl: tk_messageBox -title "Option A"
				  -message "Option A is working.""/>
  <item tag="Ext_Filemenu_HV1_B"
            text="Custom Option B"
            hint="Custom file menu sub-entry B"
            command="tcl: tk_messageBox -title "Option B"
				   -message "Option B is working.""/>
   </button>
   <button        tag="Ext_Filemenu_HV2"
                  text="Custom Entry 2"
                  tooltip="Custom file menu entry 2"
                  image="fileOpenStrip-24.png"
					  Custom Entry 2" -message "
					  Placeholder for a custom
					  open procedure."">
   </button>
</root>
