Create Beam Sections
Create and edit beam sections of different sources and engines.
Create a beam section in one of two ways:
  • Directly from the browser.
  • From the 1D ribbon, select the Beam Section tool.
    Figure 1. Beam Section tool
A beam section entity is created and the Create Beam Section dialog opens.
Tip: From the 1D ribbon, select the Beam Section Browser tool to filter beam sections in the Beam Sections Browser.
Figure 2. Beam Section Browser
Create Standard Sections
Standard sections are predefined shapes from a database with dimensions like Channel, Hat, I, or L sections. Most of them are directly available in the solver. Section properties are evaluated using a closed form solution.
  1. Set the Source to Database.
    Engine will automatically set to Closed Form.
  2. Change the section type to the desired shape.
  3. Define the beam section parameters.
    Listed dimensions are based on the selected shape.
    Hover your mouse over an option to view a diagram.
    Figure 3. Create section from database
Create Generic Sections
Generic sections define sections without defining actual cross-section geometry.
  1. Set the Source to Generic.
  2. Enter desired geometric properties such as Area or Iyy/Izz.
  3. For warping properties, provide:
    • Shear center location Ys/Zs
    • Torsional constant J
    • Warping constant
    The Y axis (resp Z) values define values in the beam elemental system. The origin of the local system can be defined anywhere; in this case, properly enter the coordinates of the section’s Centroid Yc/Zc.
    The values mapped to the property are the components of the Centroid from Shear center, independent of the local origin used in the beamsection.
    Figure 4. Create Generic section input
Create Shell Sections
Shell beamsections use thinwall theory and represent a section as a collection of parts.
Each part is a list of vertices (to form straight segments) with constant thickness assigned.
Assign Sketch Entities
  1. Select a shell beam section in the browser, or create new one and set the source to shape and engine to thinwall.
  2. Optional: Edit default thickness in File > Preferences > Meshing > Advanced.
    Automatic sets the default thickness as 1/10th of Default size (global mesh size).
    Manual lets you set your own default thickness.
  3. In the Entity Editor, select an existing sketch entity.
  4. Optional: Use the Tabular Data to change each part's name and/or thickness (size).
  5. Optional: Choose a center option.
    Base point
    Uses the sketch origin as the beam section local origin.
    Centroid
    Uses calculated Centroid as beam section local origin.
    Shear Center
    Uses calculated Shear center as beam section local origin.
    If Shear Center is undefined (disconnected parts), it defaults to frame center.
    Frame Center
    Place the beam section local origin at the sketch’s bounding box center.
Any type of (non-empty) sketch entity is valid to be assigned to the Shell config. A shell beam section is hence populated from the internal realization:
  • Lines are extracted from the assigned sketch (independent of any current geometric realization)
  • Lines are split in several parts if there are either T-junctions or disconnected parts.
  • Parts are defined as a collection of sketch line IDs (Definition in tabular data).
    • They have Type = Shell.
You can review and edit the realized beam section in the Section Manager.
Update Beam Sections with Sketches
A sketch entity assigned to a section along with tabular data (part names/thickness) is the main source that regenerates beam section realization upon change.
The beam section entity listens to sketch updates either from direct sketch edit or parameter changes if the sketch is parametrized.
  • To update beam section shape:
    • Right-click on a beam section in the browser and select Edit to open the Section Manager, which includes the Sketch ribbon.
    • The beam section properties are only updated when you exit the Sketch tool.
    Figure 5. Edit in the Section Manager
  • If the sketch has variable assigned to it (parametrized):
    • From the Sketch ribbon, click the Variable Manager tool and update variable values.
    • Or, use the Parameters Browser and update parameters.
    • Beam sections are updated each time a variable is changed.
    Figure 6. Parameter Browser and Variable Manager
  • To update the part thickness of each section part, use the dedicated column in the Section Manager.
Create Welds
The best way to manage welds whenever a sketch is assigned to a beam section is to include the welds lines in the sketch directly. Updating the sketch size keeps welds.
Whenever parts are detected from the assigned sketch, then update relevant part names to use weld1, weld2 … This convention is used in the Inflate tool which generates surfaces and shell mesh from beams with shell beam sections; weld* parts are ignored while generating surfaces.
  1. Select one or several beam sections (shell only) in the beam section browser.
  2. Right-click and select Auto Connect.
    This tries to enforce weld creation based on part distance and thickness. There are no inputs required. The result is as per the description of the API *beamsectionautoconnectshell.
Absorb Sketches
Legacy shell and solid beam sections of config shell (and solid) are automatically absorbed when reviewed for the first time in the Section Manager. That is, a Sketch entity is created from raw data of the beam section. (Figure 7).
Only orphan beam sections are absorbed.
  1. Select one or more beam sections in the beam section browser.
  2. Right-click and select Absorb Sketch.
    This option is only available if at least one of the selected beam sections is Shell or Solid. If a beam section already has a sketch assigned the nit is kept.
    Figure 7. Sketch absorbed from shell section
Limitations
  • The new data structure does not have the same limitation as the legacy Shell part structure (no part can span across the T junction in legacy); hence, the number of parts may differ after absorption. Therefore, you lose the original part distribution as well as name/thickness.
Solid Sections (Legacy)
Solid beam sections are meshed sections without considering material distribution. Also, sections are made of a single part since there is no provision for weld/contact in the engine used to evaluate the section’s properties.
Like Shell sections, Solid beam sections can be linked to a sketch entity (beamsections_create_t_2.htm#task_am4_3zb_3vb__fig_m5t_ywc_3vb).
  1. Select a solid beam section in the browser.
  2. In the Entity Editor, select an existing sketch entity.
  3. Optional: Choose a center option.
    Base point
    Centroid
    Shear Center
    Frame Center
A sketch assigned to a Solid beamsection is valid only if at least a surface can be generated from it. If a sketch describes closed loops and extra lines not forming a loop, the later are ignored. If no surface can be generated the sketch, it is rejected.
Solid beam sections are hence populated from the mesh of the internal sketch realization:
  • Surfaces are extracted from the assigned sketch.
  • A disconnected region triggers multiple parts.
    • This is usually not desired as Warping properties can’t be calculated.
    • Geometric properties are valid.
  • Parts are defined as a collection of sketch line IDs forming loops.
  • Parts are meshed with an auto-calculated mesh.
Figure 8. Solid section in the Section Manager
Absorb Sketches
Legacy shell and solid beam sections are automatically absorbed when reviewed for the first time in the Section Manager. That is, a Sketch entity is created from the raw data of the beam section.
Create Elastic Sections
Elastic beam sections are 2D meshed sections. They are an extension of the legacy Solid sections.
Theory
Elastic sections can have two types of parts internally:
Solid
Defined as a closed loop of lines.
Shell
Defined as lines and thickness. The thickness is used to inflate lines symmetrically to turn them into surfaces and 2D mesh them.
Material
Elastic sections can account for materials per part. Only linear elastic isotropic materials are supported. The engine uses Young Modulus, Poisson ratio, and Shear Modulus to evaluate EA, EIyy, EIzz,EIyz, GJ.
In the case of multi-materials, the engine evaluates the stiffness terms, then defines an effective material (homogenized) from the various materials and their areas in the section (it is possible to provide a target material to the engine). Section Centroid is the material weighted neutral axis. Shear Center and warping properties also account for material data using elasticity theory.
More information is available to reference:
  • “Analysis and Design of Elastic Beams: Computational Methods, Walter D. Pilkey”
Note: Consider the following points:
  1. Elastic sections evaluate stiffness terms.
  2. Target solvers only know about a property entity and a material entity.
    1. Properties store geometric data like area and second moments of inertia.
    2. Materials store Young/Shear moduli and Poisson ratio.
    3. A stiffness matrix is formed as a product of the two separate.
  3. It is then needed to normalize the data with the homogenized material to fit in the solver data structure.
Elastic beam sections considering material information are only available in the Section Property tool with Update beam (see Update Beam elements) as it not only creates a beam section but a property with the correct material.
Any other tools dealing with elastic sections ignore materials.
Contact
Elastic sections support multiple parts with small gaps:
  1. Shell type sections are first inflated based on their thickness.
  2. All parts are then considered for contact search between all bodies.
  3. Contact can be turned off.
  4. You can set the tolerance.
  5. Default (Best match) is around 80% of the average mesh size in the section.
    Keep in mind that a thickness of 4 elements is ensured during shell part inflate.
When a sketch is assigned to a beam section, default contact is always used.
Create and Edit Elastic Sections
  1. Create a new beam section from the browser.
  2. Set the source to Shape and engine to Elastic.
    The section has no default shape, hence all properties are 0.0 like a Generic section.
  3. Optional: Edit default thickness in File > Preferences > Meshing > Advanced.
    Manual lets you set your own default thickness (used for Shell parts).
  4. In the Entity Editor, select an existing sketch entity.
    Base point
    Centroid
    Shear Center
    Frame Center
Elastic beam sections are split into multiple parts from sketch lines:
  • Surfaces are extracted from closed loops and considered as Solid parts with Type = Solid.
    • Disconnected regions trigger multiple Solid parts.
  • Other lines (not forming closed loops) are considered as Shell parts with Type = Shell.
Hybrid Sketch and Contact
The following example (Figure 9 & Figure 12) depicts a hybrid sketch where 4 lines form a closed loop and 3 lines an open section. In this example, the Gap parameter is introduced to control distance between 2 shapes.
The closed loop is understood as a Solid part while the open section is considered a Shell part.
In Figure 12, we assigned a thickness of 10.0 to the Shell part. Then, we played with the gap variable from 6.0 to 10.0.
  • In the first case, the final gap after inflating is 1.0, which falls under the tolerance; hence, a contact is created between parts. Warping properties are evaluated.
  • In the second case the final gap is 5.0, which is too large for this model; hence, no warping properties are available.
Figure 9. Hybrid sketch
Figure 10. Elastic hybrid section with contact due to gap
Figure 11. Elastic hybrid section without contact due to gap
Solid Sketch
Using the same original sketch, you can use the Sketch Offset tool to create a symmetric offset of the open section to turn it into a closed loop of lines. Click and drag the offset to play with the solid section's thickness or enter a precise value (Figure 12).
Figure 12. Offset lines in sketch with parameter
In Figure 13, we super-impose beams in 3D detailed visualization where:
  • the top beam has a property referring to a hybrid sketch with a shell part of thickness 10.0.
  • the bottom beam has a property referring to the offset sketch from Figure 12.
You can see that the calculated section properties are almost identical.
Important: The original midline of the Channel was turned into Construction Lines. Otherwise, the Elastic beam section would have detected these lines as a separate Shell part on top of the Solid Channel.
Contact management is the same in both cases (hybrid or full solid).
Figure 13. Hybrid sketch versus solid sketch
