Create a Frequency vs. RPM Waterfall Plot
                From the HyperGraph 3D toolbar, click the Waterfall
                    icon,
             - Under Plot type:, select Frequency from the first drop-down menu and Input magnitude from the second drop-down menu.
 - Under Data curves:, enter a p#w#c#.vector curve reference in the Response= field manually, or press Shift and left-click an RPM curve in HyperGraph 3D.
Or
                Use the curve selector.
                         Click the curve selection button,
, in the Response text box to display the Response dialog.
                     - Choose a curve from the tree and click Select.
 - You can also click Preview to view the curve before selecting it.
 - Click Close to close the Response dialog.
 - Under Data curves:, enter a p#w#c#.vector curve reference in the Input= field manually, or press Shift and left-click an RPM curve in HyperGraph 3D. Or, use the curve selector. See Step 3.
 - Under Waterfall slices:, select Number: and enter the number of slices for the waterfall plot.
Or
- Select Step size: and enter a step size based on the time vector of the response curve.
 - Click Apply.
