Copy a Curve from an Active Window
  1. From the Define Curves dialog, select a curve from the Curve list or pick a curve from the active window.
  2. Click Copy from the curve list controls.
    The selected curve is copied to the clipboard leaving the original behind. The copied curve can be pasted in any window.
