Reference a Datum Plane Intersection from an XY Plot Window
- From the Select application drop-down menu, select HyperGraph.
- From the Define Curves panel, add a new curve.
- Under Source, change the curve type to Math.
In the x= or y= fields, enter p#w#d#.vector to reference
the planes intersection of the curves.
The vector is either X or Y to select the values along the plane’s length or height. For example, p1w1d1.y selects the plane’s local Y values for the first datum plane in window 1 of page 1.
