Plot an Order in an XY Plot Window
- From the HyperGraph 3D Data Query panel, select one or more cut surfaces from the Cut list.
 - Under Create curve:, from the first drop-down menu, select the X, Y, or Z axis of the 3D plot as the independent axis for the created curve.
 - Under Create curve:, from the second drop-down menu, select the X, Y, or Z axis of the 3D plot as the dependent axis for the created curve.
 - Set the Layout to One plot or One plot per cut to place all created curves in one plot window or each curve in its own plot window, respectively.
