2026
Solvers and translators supported in MotionView.
View new features for Altair HyperWorks 2026.
Load a different solver interface in the application.
Supported solvers in HyperMesh.
Supported solvers in HyperView.
Supported solvers in HyperGraph.
Translators are utilities that are run from the command line of the operating system to convert various types of results files into a format that the program can read. A table of the translators supplied with the programs appears below. Since the program can read HyperMesh binary results files, the entire set of HyperMesh results translators is included.
Learn about MotionView interfacing with solvers, MotionView SolverMode, and how to execute solvers.
Overview of how the MotionView applications interface with the Abaqus solver.
Overview of how the MotionView applications interface with the ADAMS solver.
Overview of how the MotionView applications interface with the MotionSolve solver.
MotionView can interface with Mechanical Simulation Corporation’s Carsim product.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
