Description process
Introduction
A time dependent study / parametric analysis unfolds in the same manner as a "classical" study.
Supplementary stages are inserted into the main ones, in the various modules: geometry building, meshing, physics, solving process, results post-processing.
Process (1)
Various definition stages of a time dependent study are presented in the table below.
It is a simplified summary of the description process, within which the time dependent studies have been separated (individualized). The most general case is a mixture of these various studies taken individually.
Stage Description
0 Automatic creation of parameter TIME
1 Definition of variable quantities in function of time
via TIME parameter via I/O parameter
  • direct use of parameter TIME
  • creation of an I/O parameter (formula or table) in function of time
  • use of this parameter
2
Creation of sensors*
(to evaluate the quantities on various supports, etc.)
3
Creation of a scenario to control the solving process
(definition of the I/O parameters variations)
4
Solving process
with the scenario prepared in stage 3
5
Results post-processing
of the scenario prepared in stage 3 (see § Results post-processing )
Note: * If the sensors have not been created before the solving process, they can be created and evaluated afterward within the post-processing context.
Process (2)
Various definition stages of a parametric analysis are presented in the table below.
It is a simplified summary of the description process, within which the geometric and physical parameterized analyses have been separated (individualized). The most general case is a mixture of these various studies taken individually .
Stage Description
1 Creation / use of I/O parameters
If … then …
parametric geometric study
parametric physical study
  • creation of a controllable I/O parameter
2
3
4
Solving process
5
