Import of a list of points in a multipoint support
Introduction
The creation of a multipoint support is carried out by importing of a list of points.
The corresponding command permits to create a multipoint support starting from the nodes coordinates of another application, in order to prepare the data exchange between two applications of different nature.
Create a multipoint support
To create a multipoint support by import of a list of points :
| Step | Action | |
| 1 |
In the menu Parameter/Quantity:
| → | A dialog box «New multipoint support ….» is opened | |
| 2 | Choose the Name of multipoint support | |
| 3 |
Specify the file to be imported:
| 4 | Choose a fixed support and pass to step 5 |
Choose a mobile support:
| 5 | Validate by OK | |
| → | The multipoint support is created and it appears in the data tree | |
