SimLab Tutorial: Multi-physics (EM, NVH, CFD) Analysis of a 75 kW PMSM - Motor Mode
The studied device, represented in the following figure, is a surface inset permanent magnet synchronous machine (PMSM) used on traction applications with a 75 kW power rating. It is a three-phase machine with 45 stator slots and 10 rotor poles made from M800_65A steel. It operates in the motor mode in this application case.
After the 2D transient magnetic is finished, the post-processing results, such as stator tooth electromagnetic forces and loss distribution can be used for further NVH (with OptiStruct) and CFD (with AcuSolve) analysis. The electromagnetic forces acting on stator teeth computed in Flux will be converted to Load Case for OptiStruct to run a 3D NVH analysis. And all loss results obtained with Flux will be converted to Heat Sources for AcuSolve to run a 3D CFD analysis. The multi-physics analysis workflow (with the outside airflow considered) is shown below:
Analysis 1: 2D transient magnetic analysis
The objective is to calculate electromagnetic torque and other electrical parameters (phase voltages, phase currents, power, losses, etc.) for different rotor positions under transient analysis. In this case, the transient magnetic application is coupled with an external three-phase circuit (created by the Circuit Template) while varying rotor position.
Analysis 2: Vibration and acoustic analysis
Once the PMSM is electromagnetically computed, the second step is to analyze its NVH characteristics. In Flux, the most common way is to export the electromagnetic forces acting on stator teeth from the transient magnetic analysis and run the NVH analysis with OptiStruct.
Analysis 3: Steady-state CFD analysis
Staring from the 2D transient magnetic analysis, the third step is to analyze its thermal characteristics. In Flux, the most common way is to export the copper loss / iron loss information from the transient magnetic analysis and run the CFD analysis with AcuSolve. The following temperature distribution figure provides a primary analysis of the thermal characteristic inside the motor.
Example access
All files corresponding to this example are accessible in the following link: Tutorial package.
Note: The tutorial packaging may evolve with each new version, but not mandatory. The latest version of the tutorial package will automatically work with the most recent release of SimLab.
  • to follow the example step by step, the corresponding files are in "StepByStep" folder containing:
    • a document of training about SimLab eMotor modeling
    • Part_1_EM folder:
      • the document describing the example step by step
      • the CAD file to import
      • *.slb databases an other files needed to be able to play manually the tutorial by following the step by step document
    • Part_2_NVH folder:
      • three documents describing the example step by step
      • the Flux project solved
      • *.slb databases an other files needed to be able to play manually the tutorial by following the step by step documents
    • Part_3_CFD folder:
