Setting up the PBS Job Template File
The job template file contains a set of instructions for the PBS cluster. This list of commands is used for each sweep configuration when submitting the runs to the cluster.
Note: Before submitting jobs to the cluster, verify the
pbs_job_template.sh settings with the PBS administrator.
Open the pbs_job_tempalte.sh file in a text editor
(Notepad++ recommended).
Note: For Windows workstations, set the end of line character (EOL) to Unix(LF).The following template is displayed.
#!/bin/bash # Simple example for a job script for using Altair Feko # with a queuing system (PBS, ...) # ------------------------------------------------------------- # General settings for PBS #PBS -l select=2:ncpus=4 #PBS -l walltime=1:30:00 #PBS -k oe #PBS -V # General settings for the Altair Feko job # Point to the Altair Feko installation from the PBS Home directory cd $PBS_HOME . ../../opt/altair/2018.2/altair/feko/bin/initfeko - Change the #PBS -l select instruction to the required number of compute nodes and cores to be used per run, for example, #PBS -l select=2:ncpus=4 indicates that two compute nodes and four cores are used per run.
- Change the #PBS -l walltime = Hours:Minutes:Seconds instruction to the expected runtime of a job.
- [Optional] Add additional #PBS instructions as required, for example, to direct output of error feedback to a custom directory.
- Change the location from the $PBS_HOME directory to point to the Feko installation.
- Save the file pbs_job_tempalte.sh file.
