Overview
The application macro is divided into two parts. The first part in CADFEKO creates the models to submit to a cluster. The second part in POSTFEKO merges the results.
- Farm model to cluster: The application macro splits the original CADFEKO model into individual models using the frequency and plane wave source setup per configuration.
- Combine results from cluster: The application macro uses a .xml summary file as input to merge the individual runs from the cluster and store the data in POSTFEKO.
