Viewing the Near Field Results (2D)
Create a new Cartesian graph. Create two near field traces and compare the Ey and Ex components of the near field along the X direction.
On the Home tab, in the
Create new display group, click the
Cartesian icon.
Add the near field result to the Cartesian graph.
Add results group, click the
Near Fields icon. From the drop-down list, select
NearField1.
View the near field along the X direction.
View the magnitude of the Ey component of the field.
Add a second trace to the Cartesian graph by duplicating
the NearField1 trace.
On the Trace tab, in the
Manage group, click the
Duplicate trace icon.
A second trace, NearField1_1, is created. -
View the magnitude of the Ex component of the field.
- On the result palette, select the NearField1_1 trace.
- On the result palette, in the Quantity panel, select the X check box and clear the Y check box.
Set the vertical axis to dB.
- In the result palette, select both traces (NearField1 and NearField1_1).
- In the Quantity panel, select the dB check box.
Modify the minimum and maximum values for the vertical axis.
Figure 4. The Ey and Ex components of the near field along the X direction.
