Viewing the Far Field Results (2D)
View the far field results on a polar graph.
Note: Since a full 3D set of data was requested for this example, 2D cuts can be
extracted.
Create a new polar graph.
On the Home tab, in the
Create new display group, click the
Polar
icon.
Add the far field result to the polar graph.
On the Home tab, in the Add results group, click the
Far field icon. From the drop-down list, select
FarField1.
View the far field gain plotted in the YZ plane.
On the result palette, in quantity panel panel, select the dB check box.
Figure 1. The far field results on a polar graph.
