Viewing the Far Field Results (3D)
View the far field results in the 3D view.
- Select the 3D view window.
Add the far field result to the 3D view.
On the Home tab, in the Add results group, click the
Far field icon. From the drop-down list, select
FarField1.
Hide the near field result still displayed in the 3D view.
Add an annotation to the far field.
- Add an annotation to the desired location by pressing Ctrl+Shift+left click.
View the fields in dB.
- On the result palette, in the Quantity panel, select the dB check box.
Change the size of the far field compared to the geometry.
