Script - RADHAZ Safety Zone Using NRPB 89 Standard
This script generates a near field result that incorporates the calculated near fields and the NRPB 89 safety standards.
The normalised threshold as per NRPB 89
Each near field value is processed and normalised to the maximum field value that the
standard allows for that frequency. A value of 1
corresponds to the field threshold
according to the standard. A value higher than 1
is over the limit and a value lower
than1
is a safe zone.
-- This example illustrates how advanced calculations -- can be performed to display radiation hazard zones. -- The NRPB 89 standards are used. nf = pf.NearField.GetDataSet("yagi.StandardConfiguration1.nf3D") function calculateRADHAZThresholds(index, nf) -- Get a handle on the indexed near field point local nfPt = nf[index] -- Set up the threshold according to the standards -- Frequency in GHz local freq = nfPt:AxisValue(pf.Enums.DataSetAxisEnum.Frequency)/1e9 local EfieldLimit = 97.1*math.sqrt(freq) local HfieldLimit = 0.258*math.sqrt(freq) -- SCALE THE ELECTRIC FIELD VALUES -- Scale the values to indicate percentages. The percentage represents -- the field value relative to the limit of the standard. nfPt.EFieldComp1 = nfPt.EFieldComp1/(EfieldLimit) nfPt.EFieldComp2 = nfPt.EFieldComp2/(EfieldLimit) nfPt.EFieldComp3 = nfPt.EFieldComp3/(EfieldLimit) -- SCALE THE MAGNETIC FIELD VALUES -- Scale the values to indicate percentages. The percentage represents -- the field value relative to the limit of the standard. nfPt.HFieldComp1 = nfPt.HFieldComp1/(HfieldLimit) nfPt.HFieldComp2 = nfPt.HFieldComp2/(HfieldLimit) nfPt.HFieldComp3 = nfPt.HFieldComp3/(HfieldLimit) end pf.DataSet.ForAllValues(calculateRADHAZThresholds, nf) -- Note that in essence, the values being returned are -- no longer near fields. As such, interpret them -- carefully in POSTFEKO. return nf
