Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Import the Parasolid geometry of the car from the file
car_geometry.x_b
Note: The model is included in the Feko installation.
Rename the three imported parts as follows:
- The structure for the car: car_body.
- The structure for the antenna: antenna.
- The structure for the windscreen: windscreen.
Union car_body and antenna.
Note: The windscreen curvature reference is not part of the union as it is not required to be electrically connected to the model.
- Add a wire port to the start of the line.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
Create a dielectric medium (glass).
- Relative permittivity: 7
- Dielectric loss tangent: 0.03
- Label: glass
Create a dielectric medium (PVB foil).
- Relative permittivity: 3
- Dielectric loss tangent: 0.05
- Label: pvb_foil
Create a layered dielectric (2D).
Create a windscreen medium.
Specify the windscreen curvature reference.
A windscreen curvature reference is displayed semi-transparent in the colour of the windscreen definition.
Specify the windscreen antenna (wires).
Figure 1. 3D view showing the selected windscreen antenna.
- Set the continuous frequency range from 90 MHz to 110 MHz.
