Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Use the model considered in Pin-Fed, SEP Model and rename the file.
- Delete the substrate part contained in the antenna part.
Add a planar multilayer substrate (infinite plane) with a conducting layer at
the bottom.
