Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Define the following variables:
- d = 2.25 (Distance between dipole and plate. [3*lambda/4])
- h = 1.5 (Length of the dipole. [lambda/2])
- a = 4.5 (Half the plate length.)
- rho = 0.03 (Radius of the wire.)
Create the dipole.
Create the plate.
- Add a wire port to the middle of the line.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
- Set the Frequency to c0/3.
