Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Specify local mesh refinements.
- Set a local mesh size of lambda_b/40 on all four edges of the patch.
- Set a local mesh size of ap_w*0.7 on all four edges of the aperture.
- Set a local mesh size of feed_w/4 on the face of the feed.
