Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
Define the variables and media.
Create the aperture.
- Repeat Step 5 in SEP Model.
- Set the solver method for the aperture face to use Planar Green's function aperture.
Create the patch.
Create the microstrip feed line and plate (via) that connects the infinite ground plane and feed line.
Create the positive and negative terminals of the edge port.
- Repeat Step 11 in SEP Model.
Create an infinite ground plane using a planar multilayer substrate with a
conducting layer at the bottom.
- Union all parts.
Add an edge port, voltage source, specify the frequency and define symmetry.
